FIRE PIT ART 24 IN. MAGNUM WITH LID ELECTRONIC FIRE PIT NATURAL GAS
Features- The standard Saturn has a 40 in. OD and an ID of 28 in. and is 14 in. tall. Magnum has an OD of 54 in. and an ID of 35 in. and stands 18 in. tall with a ring width of 9 in.
- Ignition System - Electronic - All Weather Electronic Ignition System includes 24 volt AC Transformer Fire Module Heat Shield and Install Instructions.
- Included - Comes complete with fire pit 120K BTU Brass Crossfire Burner Lava Rock Flex Line Kit and Plate.
- Design - Magnum w/lid
- Burner - 120K BTU Crossfire Brass Burner
- Pan Size - 24 in. diameter
- Flex Line & Valve Kit - 0.5 in. lines
- Product Materials - 0.25 in. Thick Mild Carbon Steel
- Fuel Type - Natural Gas or Liquid Propane
- Finish - Iron Oxide
- Diameter - 28 ID/40 OD
- Base Height - 7 in.
- Base Diameter - 23 in.
- Size - 14 x 14 in.
- Fire Pit Weight - 310
- Lava Rack - 50 lbs.
Price: 5393.70
